apjcustoms
ok so just purchased an 03 quad cab 1500 200k lifted with a mystery motor swap with around 110k on it . outside of obvious wear and tear repair items I have a serious issue really stressing me and I've spent hours and a few hundred bucks without resolve ! the truck will just shut down usually when I'm off the gas peddle at idle or just shifting into gear it has shut down a handful of times while driving down the road but not as common and now today when I go to start it turns over and cuts out then I recycle the key and starts no problem ! I replaced the ignition switch where I discovered some scortch marks from extreme heat due to a poorly wired remote start and some mystery wires just loosely ******* . so I removed the wires and disconnected the remote start system and still the problem persist ! its not a fuel supply issue the truck would continue to crank if it were this is electrical only codes I'm getting are p0443 for the evap circuit a swapped in a new purge valve but its not pumping so I'm thinking maybe PCM I replaced all replays and nothing is blowing or heating up any input would be helpful !
