dkelly3103
Hello everyone, this is my first post on here so hopfully it’s in the right spot. I have a 2010 ram 1500 SLT quad cab. Just bought it 6 months ago and it’s been a great truck so far. When i bought it, it came with one key fob. It worked flawlessly for the first few months then I accidentally let it go through the washer, it then started acting up and only working part of the time and had to press the buttons multiple times for it to work. Although it still started the truck with no problem. I bought a new key fob and had it programmed thinking that would solve my issue. Immediately I noticed it would not lock, unlock or remote start my truck. Only start it using the key in the ignition. At this time my old remote still worked occasionally so I assumed it was just a problem with the new remote not the truck however once I got home from getting it programmed neither the new remote, or my old remote do anything at all to the truck using any of the buttons. No panic, unlock, lock or remote start. Both still start the truck. Was it just a coincidence that the old remote stopped working entirely the same time I had a faulty new fob programmed or is it possible there’s a issue with my truck? Sorry for the long post just wanted to give as much detail as possible to help clarify the issue.
