KYB shocks with 4" rear drop
Lawhand
Baton Rouge, LA
Anyone else with a 4" rear drop running KYB monotube gas-a-just shocks? i got these because they were suppose to help me haul stuff around with a 4" drop. had them on for about 8-10 months now and all i hear is a clang sound coming from them. do i need "lowered shocks" as in a shorter shock or would a stock shock still work just fine. i feel like the piston is hitting the end of the shock and causing this noise.
any thoughts would greatly be appreciated
TylerB
FL
You need a shorter shock or fabricate some shock extender mounts.
L
Lawhand
Baton Rouge, LA
it happens when going over smaller bumps. if that helps any. going over small speed bumb cuase it as well, but bigger speed humps cuase no noise at all.
