LA for Magnum Swap
Deblackmon3
South Carolina
LA 318
If you guys remember my thread from a few weeks ago, I was having trouble with my LA 318. I took the engine out yesterday, which was incredibly annoying considering all the smog pipes and that the torque converter didn't want to turn for the longest time (had to bust out a crow bar and turn it by hand for like 30 minutes to get all the bolts off). Until I can rebuild the 318 I'm thinking about just buying a Magnum as a stand-in. Is there any major systems that need to be updated/replaced for a magnum to work? I have a '90 D150 TBI.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
The Magnum will drop right into place, however you're going to need to swap over all your TBI crap including the intake manifold. You're actually almost better off (IMO) in just waiting till the LA is rebuilt or getting a Magnum parts truck and do a full Magnum swap into your truck.
Deblackmon3
Deblackmon3
South Carolina
LA 318
See, I WOULD rebuild it and then put it in later, but I need to get my truck to be drive-able asap. I don't have another car to drive and I need something for transportation. How much time would it take to do a full swap would you wager?
If I don't get a Magnum, it would be a switch to a 318 carb, but that would still require swapping the intake and all that junk... Ughhh.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Yeah, but here is the thing, a stock Magnum makes 50+ more horsepower and torque than a LA. Not only that, but it can be made to go faster with less mods and takes to carbing rather well.
It would take a while I'd imagine. lol Could probably done in a week if you take your time.
I'd advise you wait around for crazzywolfie to weigh in.
Deblackmon3
Deblackmon3
South Carolina
LA 318
crazzywolfie is the like master of first gen xD
84D100
Greeneville,Tn
I pulled a stock 318 out and put a small cammed carbed magnum 318 in my truck I love it! Truck runs great still gets pretty good MPG when I keep my foot out of it.
88rambigblock
wv
1970 coded 440 big block
the swap is very simple. 1st get a carb intake manifold for the magnum motor, and carb. if the exhaust doesn't line up then take it to your local exhaust shop.
crazzywolfie
under the truck
i completely missed this thread. depends which way you want to go. if you want to keep things fairly simple get a carbed intake and get an adapter plate to bolt your throttle body to.
now if you want to go MPFI then things get a bit more complicated because you will most likely have to build a custom harness to run the engine.
DodgeAddict
Chambersburg PA
5.9 Magnum
Here's how a Magnum looks when done with a Performer RPM & factory Magnum serpentine drive using A/C lines & compressor from a 92-93 truck
Deblackmon3
Deblackmon3
South Carolina
LA 318
Wow... it looks so small in there haha. That definitely looks easier to do than trying to get the electrical set up properly.
DodgeAddict
Chambersburg PA
5.9 Magnum
I made mine difficult but really it's a walk in the park
My thread on my RamCharger shows the tricks to doing it
DodgeAddict
Chambersburg PA
5.9 Magnum
I'll be putting the RamCharger's present engine in my CrewCab & the RC will go fuelie 5.2 Magnum using a 92 Canyon Sport as a complete donor for wiring, dash, everything
