larger gas tank
WildcatHemi
Kingwood, Texas
i have the 26 gallon tank. is there a larger bolt in tank from another model or year that fits a 2003? i saw somewhere that there is a 36 gallon tank available.
any insight into extending my 265 mile range?
BWL
Embrace the skeptisism
BC Canada
If it's a long bed titans 60 gallon tank may fit. (titantanks.com). They're pricey though. You could also consider running an aux fuel tank in the bed.
nekkidhillbilly
hemi
long beds have a 36 gallon tank but it will in no way fit a shortbed. a titan tank is diesel tank so it wont work with a gas truck.
Backroad Joe
2006 4x4 2500
HEMI 5.7
My 2500 4x4 short bed has a 36 gal tank. don't know if it would be a direct bolt in for your 1500.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
If you are not concerned about where your spare tire is kept, you can put a 20 gal tank in it's place
korby05
Delta, PA
5.9 Magnum
There is a 32 gallon tank. I think I read somewhere you can switch that in without a problem
kwb377
B'ham AL
'14 1500 4x4
My '07 1500 2wd short bed came with a 34 gal. tank as an option.
HemiLonestar
Navy Badge Coast Guard
MD
3rd gen options were 34 & 35 gallon tanks. The actual main difference for install is a different mounting strap at one end. Not positive, but I think the same pump will work (compare part numbers).
Drunken Hamster
Turncoat Ford Boi
South Carolina
was 2005
was 5.7 Hemi
Redtruck-VA
Virginia
The truck is lowered with roll pan and the tank has never hit anything which is more than can be said for the original tank.
Ground clearance is not an issue.
Drunken Hamster
Turncoat Ford Boi
South Carolina
was 2005
was 5.7 Hemi
So when I do mine, I still have vertical room for more volume in the tank, then. Okay. Good to know.
Redtruck-VA
Virginia
Its basicsly a modified mustang 20 gallon tank that some hot rodders like to use. For a street truck that gets 10mpg at cruise it is as small as anyone would want to go. Obviously not for everyone.
Drunken Hamster
Turncoat Ford Boi
South Carolina
was 2005
was 5.7 Hemi
Ah. I was planning on a custom welded aluminum tank with a side fill tube instead of a bed fill setup.
Sent from my magic 5-inch
Redtruck-VA
Virginia
Side fill is a challenge to route the fill tube around the frame.
Drunken Hamster
Turncoat Ford Boi
South Carolina
was 2005
was 5.7 Hemi
There are, what, 2 inches between the bed and the frame? Should be enough... If not, maybe route it around the end of the frame and cut a hole in the bumper mount or something?
Redtruck-VA
Virginia
I'm sure you can figure something out.
mvm2
