Tentoesp
I have been hearing a noise coming from the driver's side wheel only when making right hand turns. The noise is repetitive with each rotation of the wheel. Today after work I looked and saw there was traces of diff fluid on top of the knuckle, where the u joint and axel meet.
(May be obvious, but) Would this indicate the pinion seal has failed?
What would be the cause of the noise ( a dull squeak/ whirl sound)
Thank you in advance for any suggestions.
Paul
Paul
