Leak
02Steve15
Connecticut
Had water dripping into the cab from the handle inside the cab..what the hell?
It was dripping from the driver's side also..
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Check the weather stripping, some of the doors cut it on the first few of the 3rd gens, think they changed the seal in late 04.
02Steve15
02Steve15
Connecticut
oh alright i know what you mean..i'll check if that's damaged or cut
02Steve15
02Steve15
Connecticut
hard to tell...i couldn't see any cracks in it or anything that would cause a problem..should i just buy new ones?
RubberFrog
You need to figure out where the water is coming from before you go replacing parts. It could be coming from your third brake light (very common). The water leaks along the headliner until it finds a spot to come out.
02Steve15
02Steve15
Connecticut
ill unscrew it and see if there is water behind it..maskes sense if it's the brake light area because it's leaking on both sides..
02Steve15
02Steve15
Connecticut
took off the brake light but didn't notice any water..the truck has been out of the rain for a while now so it's possible it already dried up..next time it rains and i see it leaking i will pull the brake light again and check..thanks for the tip frog
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Yours dosent have a sun roof does it? Mine has leaked from the sunroof before about 1 inch from the piller.
02Steve15
02Steve15
Connecticut
so it started leaking from both sides again today. if it is the 3rd brake light, what should I do? does it actually need to be replaced or can I put something behind it to prevent water from getting through?
02Steve15
02Steve15
Connecticut
i unscrewed the brake light again and didn't see any water inside....i'm not sure where its coming from or where else to look
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
are you checking when you see it dripping through? that might be too late. Check while its raining. you should have any behind the 3rd brake light. If you do, some rtv or silicone tape will work. by the time the water gets to the pillars, it might be too late (the source may have already dried up)
02Steve15
02Steve15
Connecticut
it was raining the whole day today and i just checked a few minutes ago when the rain turned into snow...it was dry behind the third brake light and it was also dry on the back of the actual brake light itself...so i must be leaking through both of those seals on the doors......nice, i wonder how much this will cost
02Steve15
02Steve15
Connecticut
I'm a little confused here...am I replacing the actual door sealer or am I taking the sealer off, plugging a couple holes and putting the sealer back on? sounds like i'm just plugging some holes up...i can probably pick this up at a local autoparts store?
joshhhh
