RN627
hello,
I have a 2015 ram 3500 Laramie. Appears my sunroof is leaking and I’m not sure which way to go. Initially it would only leak at the passenger grab handle and the headliner would be damp just above.
I’ve lowered the headliner enough in the front and rear to access the drains, pulled them off and can blow through them easy enough with no obstruction.
I’ve tried doing the re calibration on the sunroof with no effect.
I’ve adjusted the glass with no effect, actually maybe made it worse as it now leaks worse I think even though the glass is flush. Now the passenger rear of the sunroof area leaks and has the headliner soaked in that area and the grab handle area is now dry. Might try adjusting again but when I first did it didn’t seem to matter which way I adjusted it, the water would still pour in with the garden hose running over top. Just left it where it seemed best.
When running the garden hose it almost seems like the rear drip tray gets overwhelmed and can’t keep up, but the drains are clear so I don’t know.
Debating a new seal or glass and seal but not sure I’ll be any further ahead. Just more money spent on it and still a leak. Could silicone it shut and not have it leak… lol. First and last sunroof vehicle I’ll buy I think.
