Mr. Baseball
I recently did a transmission service on my '98 Ram with 46re. New filter and about 6 quarts, closer to 7, and new rubber gasket.
I thought gasket was leaking but it's leaking from above. I cleaned best I could. I thought it may be o-ring for dipstick tube since leak appears to be towards front but doesn't look like it.
Are all the internal/external moving parts, such as linkage, only accessible by taking transmission apart to replace seals? I really need some advice, I spent $1,300 for rebuild 28k miles ago. Warranty is up.
If anyone has any suggestions or advice I would really appreciate your help. Thank you.
Want to add it was leaking fluid before service but thought it was gasket. Thanks again.
