Led brake lights
Ian_Olivas
San Antonio,Tx
4.7L Magnum
So I tried putting the 3057 zevo led lights in my stock circuit board for a brake light and first of all. They just stayed on while the truck was off and second they had a slow flash when the brakes were applied. Any idea why they don't work as brake lights? And is there any led light that cam be used for the brakes? They worked well and just fine as park/reverse lights, didn't even stay on while the truck was off
cliftonclendenen
York, Pennsylvania
4.7L V8
You will need resistors to run LEDs.
Ian_Olivas
Ian_Olivas
San Antonio,Tx
4.7L Magnum
3157 resistor harness and you can find them on ebay.
So I looked them up but how would these keep water from hitting the prongs on the circuit board and short it out. The harness doesn't look liken it had gasket to keep monster out and also I'm not sure the bulb end will mount to the taillight
fireguy627
Henderson, TX
4.7 Magnum
I have the same problem and I used after market resistors. I purchased a set of plug and play replacement led housings with resistors installed. Still the same problem with the flash and staying on
