LED conversion issue with weird lighting
Walleye123
Ohio
2013 Laramie
Hi !
New guy here :)
Hope someone can help me out .
I own a 2013 Dodge Ram laramie
Switched out the headlights
to Alpharex pro series…..
Turn signal is led
Bright is halogen with projector
Dim is halogen with projector
So I switched out the dim with hikari
Megatron
Switched out bright with Hikari hyperstar
What’s up with this image ????
Administrator
If the High beam are on, you won't see a flat cut off line as they don't have the shield in them.
How do you have the LED bulbs indexed?
W
Walleye123
Ohio
2013 Laramie
They are indexed at 12 and 6 oclock
rule18
Admin
Administrator
NY
2017 Rebel
Are they fully seated? Those secondary reflections show up sometimes if the lamps aren't locked in place.
W
Walleye123
Ohio
2013 Laramie
I thought they were but I will do a recheck !
Thanks
Administrator
Typically the index references the LED chip direction, side to side is 3/9 o'clock, up/down is 12/6 o'clock. You might want to try rotating the LEDs 90° to see if the output is better.
You won't get a flat cut off line from the Alpharex high beams
