LED cupholder lights.
Noneck
2013 Ram 2500 Laramie. 35's 2 inch level. Raceme. Fully deleted 5 inch FlowPro Exh
I got one of the newer center consoles with the phone holder for my 13. I got it on eBay cheap because someone slashed it up with a razor or something? I wrapped the top in a silver vinyl to match after smoothing out a couple of the cuts with sandpaper and today I added LED angel eye cupholder lights. Not sure if they will be too bright at night but they look good for now, plus I usually have drinks in the cupholder anyway. I got 75mm angel eyes with plastic lens and they fit perfectly. I tapped into the the interior dimming light circuit behind the light switch for power so they are dimmable, but they are still pretty bright. I didn't have to glue them in or anything, as they fit pretty snug. There's a possibility I may have to tint the plastic lenses or something if they end up being too bright at night dfc98df2975acc41f890ea640ad37ed4.jpgcde8bd43c87a87270c56a0841571cf1e.jpg
Brandon-w
Yukon
2015 Ram 1500
Those are wicked! Do they have the ballasts like the old ccfl ones usto have or is it just two wires?
Sent from my SM-A530W using Tapatalk
Noneck
Noneck
There's a little black plastic thingy inline. Either a ballast or something similar .
Brandon-w
Yukon
2015 Ram 1500
I like it. I may consider copying it in red.
Noneck
Noneck
Pretty bright at night, but stuff in the cupholder makes them not as bad. I still may try to dim them down. Maybe paint the plastic housing or something. 39982f3888ecebae5779d06134104e79.jpg
Brandon-w
Yukon
2015 Ram 1500
Yeah I was thinking of I was going to do it I'd paint 90% of it and leave the bottom kinda open so it shined down more than up. Looks sick though!
Brandon-w
Yukon
2015 Ram 1500
Oh yeah forgot to say... with all that neon I thought it was a skoal advertisement. [emoji1787][emoji1787]
Noneck
Noneck
I'm going over ideas in my head and I think maybe some satin black vinyl. Put in on top, then heat it then remove the outer portion that goes against the side of the cupholder. That way it's not permanent and easy to alter the amount of light showing through.
Brandon-w
Yukon
2015 Ram 1500
Yeah that may work well too! When you do post pics. I think I'm sold on the idea.
Noneck
Noneck
Brandon-w
Yukon
2015 Ram 1500
Yeah haha! Ya know if you trim that skoal lid alil and stick it over the led it may be all you need. Maybe worth a try.
Skyjockey
Lowell MA
2019 Warlock 4x4
3.6L
If they are LED you just need to add a resistor in series to drop the current.
R=E/I so R= 12v/desired currant say 10ma
R=12/.010 -> 1.2k ohms
Tweek values from there to what you want.
Better yet get a potentiometer so you can adjust brightness to what you want at any time. It just a variable resistor
Noneck
Noneck
The potentiometer sounds like a great idea. Any suggestions on what to look for? Just a 12v potentiometer?
