AWE Daniel
Banned
- Jun 29, 2010
- 3,750
- 0
- 2004
- Hemi 5.7
Okay well this got started a while back and recently one of my LEDs crapped out on me so I decided that while I was changing it out I would take pics of how to do this, because its dirt easy.
First things first you need your parts list, props to OklaHemi and where he pulled this from. http://www.ramforum.com/f76/led-dash-conversion-1495/
Remember as I am sure it says there, 02-05 have 11 leds behind there, 06+ have only 5 so order appropriately and make sure to buy a few extra JIC.
Okay so I am assuming you know how to pop off the radio bezel so take that off. Next thing is to pop off the AC vent/headlight switch trim to the left of the steering wheel, just pull there are no screws here (the panel under the steering wheel should all-ready be pulled down because you took off the radio bezel). Move the steering column all the way down to give yourself more room. Put on your parking brake, and put the gear selector down to the lowest gear so thats out of the way.
Okay so now we need to take off the plastic trim piece that surrounds the dash cluster. This is held on by two screws at the top (phillips) and pressure clips at the bottom. Take out the two screws and pull gently from the bottom and it pops off and you can pull it right out.
Now to take out the cluster itself. This is held on by two screws at the top, and two at the bottom, all at the corners. Once these are removed the only thing holding them on is the wiring harnesses.
The two at the bottom
The two at the top. You will notice that once you loosen theses the cluster can slide out before they come fully out, best to just take em all the way out so you dont lose em.
