LED Foglights
Mardye
oregon
Can I wire aftermarket foglights into the factory fog light plug?
Nick@GotExhaust
Supporting Vendor
SC
Are you saying you have fog lights and want to remove them and install aftermarket fogs? If so then yes and we offer several options. Message me if you would like a quote on something specific or to discuss what option you work best for you and pricing
M
Mardye
oregon
Yeah I hit a dear a few months back and jacked up the OE bumper so to an off-road that came with 4 LED running lights. I do have factory running lights so I wondered if I could just cut the wire and run them from the factory harness? 2017 ram 1500 sportsman
Nick@GotExhaust
Supporting Vendor
SC
Should be fine as long as the wattage for the new setup is lower than the wattage of the factory bulbs
M
Mardye
oregon
Oh well dang I’m sure these are higher since there are 4 (2 each side) at 30 watts each
caulk04
Supporting Vendor
I'd bet you're ok at 30w x4. Pushing it a touch, but probably ok.
You could use the factory wiring to trigger a new relay and wiring that's heavier.
M
Mardye
oregon
Thanks for the responses, I really appreciate the help.
aimcgma
