LED Kit For 2021 Ram Classic
Ram Beau
Petawawa Ontario
V6 4WD
Hi gang !
Just purchased a 2021 Classic
Looking for LED heads and fogs
Can anyone suggest a good brand / type ?
Thanks in advance.
Nick@GotExhaust
Supporting Vendor
SC
Are you looking for plug and play LED bulbs or replacement headlight and fog light housings? Either way we have some options for you. Message me if you would like a quote and info
Nick@GotExhaust
Supporting Vendor
SC
We offer many options
Morimoto and GTR are very good options.
Hemi395
Cape Cod MA
I second the GTR bulbs, high quality bulbs with the correct beam pattern. I've had the GTR CSP minis in my highs for years now and they work awesome.
Diode Dynamics SL1s are another great choice and made in the USA.
Nick@GotExhaust
Supporting Vendor
SC
Yeah the GTR's are a probably the best with as far as beam pattern for LED PNP bulbs.
Diode Dynamics are another good option. Good call on those.
Ram Beau
Ram Beau
Petawawa Ontario
V6 4WD
OK thanks boys. ;)
So....narrowing it down ....? Lol.
I need highs and lows and fogs.
Full kit.
GTR
I hate to sound incompotent. But can one of you lads send me an exact link to purchase the entire kit specifically for my 21 Classic ?
I just want to sure I order the right exact bulbs i need without any F-ups.
Thank you lads for all your help. Appreciated;)
Ram Beau
Ram Beau
Petawawa Ontario
V6 4WD
One more quick question
These Classic Rams ...
Is it 2 or 3 bulbs ?
High / low / DRL ?
Or just high/low ?
And if there ARE DRLs ...is it possible to get a blue bulb for them ?
Sorry lads.... Im a first time Ram owner.
High / low / DRL ?
Looks like you have Quad headlights, it's 9005 (High) and H11 (Low) and unless it's changed 9006 (fog).
You might want skip using LEDs in the lows if your in an area that gets snow/ice, the headlights will freeze over. I've seen this happen several times where my high are frozen over but the lows are fine as I run halogens in just the lows. Whichever you decide, re-aim your headlights if you change any of the bulbs.
As for the fog lights your better off to change the the entire housing to an LED type. Just putting LEDs in the OEM housing make the sorta useless for use in snow and fog. DiodeDynamics makes a kit it's the SS3 SAE Fog, the beam stays low and lights up the side of the road really good. I've used this in near white out conditions and they're definitely worth spending the extra $$ for them.
Ram Beau
Ram Beau
Petawawa Ontario
V6 4WD
I appreciate this information. And thank you for your reply
But now I'm even more indecisive lol
But seriously....thank you for the info
I've already ventured down this path that your deciding on. I run Sylvania ZXE halogens in the lows and LEDs in the highs, best of both worlds and I drive on dark country roads and have no issues with visibility.
The best lighting upgrade I've done has been the DiodeDynamics SS3 Pro level SAE Fog lights
danielmid
Southeast WI
2015 Sport 4x4
Use the Sylvania Bulb Finder to figure out the bulb numbers and locations, then jump over to Headlight Revolution to see the options for each bulb. They have a good YouTube channel with reviews for each bulb type also.
Ram Beau
Ram Beau
Petawawa Ontario
V6 4WD
WHY ....is it....everytime I try doing ANYTHING pertaining to Rams.... They are never in the damn drop-down lists of dodge models ?????
Frustrating as hell trying to find anything for this pickup
danielmid
Southeast WI
2015 Sport 4x4
Because you have a Ram not a Dodge?
Hemi395
Cape Cod MA
How do you like the ZXEs? Almost went with those for my lows before setting on the DD SL1s
I'm sure any LEDs would probably be on par if not brighter but chose them for having to dealing with any issues as far as freezing or since mines a '15 (model year tends to be light type sensitive).
I bought the ZXEs on sale and were the same price as the SilverStar Ultras, they're probably a little whiter. They work good for me, usually when I need brighter I can turn the high beams on.
ThunderMug95
North Prince George, VA
If you are going to stay with halogens in your lows, do the H11 to H9 mod. 10 seconds with a Dremel gets you 10W more…Ran this mod for years in my Quads until I installed Fahren LED’s last week.
