07carbon3
- Jan 27, 2016
- 11
- 1
- Location
- Ontario, Canada
- 2023 1500 classic
- 5.7 hemi
Hello
I’ve installed ip67 led strips along the bottom of our 1500 classic. To run the same as the interior Courtsey lights.
As the led strips are very bright and I didn’t want it too look like a body under glow and more of just a subtle light So to combat that I’ve added a dimmer to my setup.
I’m using a relay rather then just tapping directly into the positive wire of the footwell light harness.
My wiring goes as following to the relay
Pin 30: wire with inline 5a mini fuse to battery.
Pin 85: wire to chassis ground
Pin 86: wire tapped to yellow wire on the footwell light harness
Pin 87: wired to dimmer “in” positive
dimmer “out” wired to chassis ground
Dimmer “out” positive and negative wired to led strips
This setup works as it should but when the I unlock the relay chatters/buzzes until I opened the door.
What was suggested was taking pin 86 wire and adding inline a in4007 diode and then between pin 86 and 85 a 47uf 35v capacitor.
I have added a larger capacitor that did stop the chattering but the bcm eventually didn’t like it and stopped the lights from working until I removed it and took the battery negative terminal off and back on.
Any advise would be appreciated
