I ordered some LEDs that replace the oem interior bulbs. Once I get them installed, I will post pics.
I noticed on superbrightleds.com they offer canbus bulbs... I've got a 2012 ram 1500 express quadcab... do I need to order the canbus bulbs or will any of the led replacement bulbs be ok?
Would it display an error code for license plate light bulbs and other assorted exterior marker lamps and such if replaced with led's?
anyone find a good footwell kit yet?
I have installed the interior LEDs (dome light), led reverse lights and license plate lights. I bought them all from superbrightleds and they are plug and play. Their site allows you to put in your vehicle info and matches the bulb type and size, giving you options on the different colors as well. Highly reccomend their bulbs. Also, FYI, if you put the leds in and they don't light up, flip them around and put them back in.
I have also installed an RGB multiple color led footwell kit I bought from diode dynamics with a wireless remote controller allowing me to change the colors, brightness, fading, pulsing etc. for a power source, I wired into the 12v power outlet just below where my 4x4 shift knob is. Getting to the wires at the back of the plug were alittle tricky. I popped off the trim panel around the stereo then removed one screw that holds the bottom panel surrounding the 12v power outlet. The screw is visible once you take off the top panel mentioned that surrounds the stereo and it's just above the power outlet plug in.
I then gently pulled the panel that is around the outlet out towards me to where I could see the back of the plug with the wiring and unplugged it. I then climbed into the floor board with a light and pulled it towards me through a visible opening to wire up the lights using quick splice connectors supplied in the kit. Once I spliced into the wires, I fed the harness back through the opening and then pulled the plastic trim back out enough to get my other hand behind the outlet area and grabbed the harness. I then plugged it back into the outlet. I hope some of that makes sense lol. I considered doing a diy on this if enough people are interested in the process. It took me about an hour and a half to do everything start to finish.
Here is a video from their website I used to help me with the process. https://m.youtube.com/watch?v=juvFWa6PcBo
I did not drill a hole anywhere for the on off switch they talk about. I used 3m tape to tape it to the backside of the lower trim panel under the steering wheel. Let me know if you have more questions or needs pictures.... I'll try my best to help out but I'll be on nights all weekend so it might be tues-Thursday before I can get photos
It would be great if you could do the DIY write up. I would love to see how you did it with pictures as a reference.
I keep wanting to take pictures and walk everyone through what I did but I keep starting other little mods lol. Currently, I'm switching over to led switchback turn signals so once I'm done with that, I'll try to tackle a little DIY of the footwell kit. The video diode dynamics website was a good starting point that shows how to tie it all together.
