robdawg14m
So I wired up my 42" light bar this weekend and used the wiring harness with relay that was included. Everything works as it is supposed to, so the rocker switch turns the light off and on. The problem I am having is that the led rocker switch stays on even with the light off and the truck off. I wired the switch to the relay, ground, and battery with a in line fuse just like the diagram showed, but I'm assuming that the constant power from the battery is what is causing my LED problem. Will wiring the switch to the fuse box fix the problem?
