Let's see your aux switches !
yodge
Huntington Beach CA
2013 ram 1500 hemi
I know a good amount of the 09-12,a are using the oem aux panel. But for people who aren't using those or have a 13-14 what are you using for your auxiliary switches ? I have 6 which are all for lights. I have them all randomly placed and I want to do them differently. ImageUploadedByTapatalk1389765486.254197.jpg
On my ebrake is my controller for my stobes.
Next to that are three switches (red,blue,green).
Red-tailgater light,
blue- dust light,
green-exterior wheel well lights.
Right above that is another red circle switch. That's my rigid pods.
and below that on my right side is ANOTHER red switch for my 20" light bar.
I've been using red because I can tell if I leave them on. Lol. So let's see em guys !
jeepguy_1980
5.7L
Sadly, it doesn't work.... Yet.
Sent from my SCH-I545 using Tapatalk
jeepguy_1980
5.7L
The dealer. But don't waste your money. Not even the traction control or tow haul buttons work on the 1500.
jeepguy_1980
5.7L
I'm not sure why. But it doesn't work either way.
dogcar3
2012 Power Wagon
Got a little bit of a hybrid going on here. Mounted two aftermarket switches along with the OEM switches. The boxes below are for my emergency flashers.
jeepguy_1980
5.7L
Are you interested in selling? It might work on my 2500.. :emotions33:
No. I plan to make it work on the 1500. I just won't be home for anther 3 months to try.
It should work on a 2500. But you would still need a custom harness.
You can get one. The part number is 56054539AA. That is for the one pictured with a traction control button and tow/haul button.
WhiteExpress
Midland, TX
Good deal! I need one with Tire Light Load too (something else that doesn't trouble you 1500s)
jeepguy_1980
5.7L
Just call AllMoparParts.com they can get you the part.
It's still not going to work without customization. But I'm curious to know if that buttons you already have will work.
murraygc
How did you mount the extra switches?
Bigboytoys
Bamberg, Germany
2004 QC 5spd
4.7L
I know I have a 04, but here is mine...the switch closest to the EVIC is the lights behind the grill (2 100w spots) and the one behind it is the on off switch for my emergency lighting. The slide switch is setup as a sequential slide using relays and 1 way resistors. When the switch is to the left, just the amber Feniex Cannons in the reverse lights come on, middle is cannons in reverse lights, tail lights, and a Whelen Dual Talon in the back window (I am planning on hooking that into position 1) All the way right is everything in back, and the cannons in the front corners and a Feniex Apollo in the upper windshield.
Lemniscate_Mike
