Ordered the bypass just now. Getting the fluid on Amazon (7quarts) but with the ppe pan I’ve got to find two extra quarts. Looks like $35 a quart. Wow!I would change it early, were I you, good sir!!
I'd also install the @caulk04 transmission cooler bypass valve upgrade as well.
This will drop your trans temps by up to 30deg/c and your engine temps by up to 5deg/c as well.
Follow the green sheet instructions to a "T", too!!
Extremely important for our 8spd transmissions!!
