Level opinions for '15 2500 Diesel
phantom4
Orlando
Please give your opinions for best level and tire size for '15 2500 4x4. Pics also please
thanks, John
Maxtrac Suspension
Anaheim, CA
4.7L V8
We offer a 2" coil spacer with shock extenders for the new 2014+ Ram 2500/3500 4wd and here is the link to it if you would like to check the kit out... 2013-2015 Dodge Ram 3500 4WD 2014-2015 Dodge Ram 2500 4WD 2" Coil Spacer & Shock Extender
We also offer a brand new 2" coil spring replacement leveling kit for your vehicle and it comes with 4 Bilstein 5100 shocks as well. Here is the link to that kit if you would like to check it out... K832820B 2013-2015 DODGE RAM 3500 4WD & 2014-2015 DODGE RAM 2500 4WD 2" Coil Spacer with (4) Bilstein Shocks
Both of these kits are designed to clear up to a 35x12.50 tire on a 8"-9" wide wheel. Just some suggestions for you, hope this helps! If you have any questions please feel free to PM, email or give me a call. Thank you and best of luck on your search! -- Sean
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Best level... a Carli 2.5" pintop system. But do you want to spend $4100 for a leveling kit? Probably not.
To get a good quality level while staying within a reasonable budget I'd recommend a 2.5" or 3" progressive rate leveling spring with longer shocks to accomodate the level (Fox, Bilstein, whatever you prefer), and an adjustable track bar to recenter your front differential and prevent death wobble issues.
For tire size do you plan on keeping stock wheels or going aftermarket? That will change the setup a lot...
Devilman
Corsicana, Texas
Does anyone offer 1/2" to 1" coil spacer or thicker coil isolator for the 14+ 2500 with the radius arm suspension?
I've got the Carli commuter kit for my 2015 2500 and I want it to sit just slightly higher in the front than it does now
brandonjansen
I'm running a 1" Top Gun Customz spacer on top of my lift coils on my 2012. Not sure if they make something for the radius arm suspension but they'd be worth checking out.
Ghstrdr95
