Level with zone 1.5" body lift pics
tma777
Is there any cutting required with the 1.5 body lift? I know with the 3” you have to modify the bumper brackets and extend the fan shroud, haven’t seen or heard anything about the 1.5”.
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
the only thing I have seen about cutting is something on the rear bumper. I'll have to read their install instructions for more detail.
tma777
Cool, I’ll pull the directions up too. I was curious to see what those that have done the install had to say about it.
shadowhawk
Southeast WI
well, the cutting isn't to major parts, like on a 4" suspension lift. There are a few bumper mount tabs that have to come off, some cutting on the rear bumper cover, and a few drilled things. Nothing terribly frightening.
Tpearson515
Saco, Maine
Yes you have to notch out the bumper so it can clear the receiver hitch, nothing major, I used cutting wheel and painted after to prevent from rust. The bottom half of the fan shroud gets removed, and just a little bit of drilling up front to relocate the bumper and the rear bumper. If I remember all you do is once bumper is removed there is a hole already there with a guide pin, you hammer in the pin and drill it out to 1/2. So not really any measuring involved amd you dont jave to worry about it being off. It took me about 5 hours to install mine.
tma777
Cool, thanks!
shadowhawk
Southeast WI
Thanks for the pictures
NoMPG2010
For those running the 1.25 and 1.5 body lift. Can I see a photo of the back of your truck? How does the exhaust tips look
shadowhawk
Southeast WI
Tips can be adjusted.
Pa.hemi.ram
Pittsburgh
Hemi 5.7, 6" Rough Co lift, Fuel wheels, Bully Dog Gt, K&N CAI, Magnaflow Exhaust
I asked the exact same thing. Few guys helped me out and sent pics. Looks good after adjustment. My Zone 1.5 is ordered and on its way due to all the guys helpful input and pics...
Gary2
S Jersey
IMG_1102.JPG This is Bilsteins at 2.1, 3/4" rear spacer and zone 1.5" BL. I also have a PA 3" BL in the garage that will most likely replace the Zone 1.5" BL eventually.
Gary2
S Jersey
35-12.50-20 BFG KO2s. Thank you
Lifted2wd
I'm looking at the 1.5" body lift as well. I know the tips can be adjusted but I would like to see what the factory tow receiver looks like after the body lift. 1.5" doesn't seem like much but could be very noticeable.
shadowhawk
Southeast WI
I know I've seen pics of the receiver on a lifted truck. I'll see if I can find it
Tpearson515
Saco, Maine
It does not look bad imocad8234a1a534735b21c40d85d9a0713.jpgc0fb4f7ae068d5db047e156e45735f2c.jpg085a9576352c80e3d0a42729e9916157.jpg8f487e80fb3e84694a8ba9297b883400.jpg
sublime2300
