Leveled 2010 .... want more
cpc12
2010 Ram 1500 Big Horn
I just installed the upgraded Zone upper control arms and spacers to level the front. I also replaced my struts/springs and shocks if the front. In the back i upgraded to fox shocks. I just ordered 2 in rear spring spacers/risers to pick up the back a little. I now think I want to raise the front more too. i already have the zone level kit installed. can I do an body lift in conjunction with what I have ? or are there different options ?
012RAMbo
West Monroe, La
Yea, you can add a body lift to the mix. If you wanted to do a suspension lift, you would have to get rid of the puck style spacers up front and you could add a set of adjustable bilsteins or pro runners to level it back out after the lift.
C
cpc12
can anyone recommend a good 3 inch body lift.
will 35s fit under this lift.
I have brand new stuts ( springs ) and shocks in the front so I dont want to go suspension lift just body.
so in the rear I would be adding 3 inch spacer blocks and the 2 inch spring riser/puck thing. would be 5 additional in rear and 3 additional in the front ?
how many hours should this job take to install body lift for a skilled mechanic ( not me ) ?
thanks
Johnn123
Ontario
Performance accessories makes a good body lift
Yes they will!
Sounds about right, so total youll be lifted 5" in front and 5" in rear
I havent a clue how long on install, never done either jobs.
Cruizer
Ohio
2010 Sport 4x4 QC
I am running the Performance Accessories 3" body lift. Works great and comes with decent instructions. I also have 5100's at 2.8" and 1.75" rear coil spacers. I'm running 35's with minimal rubbing on the passenger's side at full lock.
Ramjoblue
Leveled 2010 want more
I have a 2010 1500 quad cab 4x4 bighorn, I just installed bilstein 5100's ride height adjustables up front set at 2.8 and standard 5100's in the rear with a ready lift 1.5 rear coil spacer. I am running 295/65r20's on factory wheels no rubbing at all !!! I will be installing a fab tech 6" lift in the spring and the will go with 20" fuel wheels and 37" toyo atII's love those tires! I will be starting a build post soon to show pic's before and after.
alphaprojects
