hodge-xj
- Joined
- Jun 7, 2013
- Posts
- 2,874
- Reaction score
- 2,463
- Ram Year
- 2006
- Engine
- 5.9 cummins
Been researching it a bunch. Found a pretty comprehensive thread on here with parts lists and everything. Aside from that Google has been quite the dead end circling me back to already viewed content. Seems pretty easy overall, still a bummer we have to swap the entire dif tho. This will be down the road a bit, prob keep this truck moderate, drop a 3.92 carrier in it and walk away. I'd rather put that time into a new trail rig and keep this thing under the KISS build ideology.Look at some of the pictures of the procedure to put them 8" low pinion in our truck and you will see what they had to mod and it would be the same mod to the drop bracket. The ring gear isn't welded in the 8" rear making it easier to swap to better gears vs our diffs so some swap the whole assembly . Google is your friend
Btw noticed you're local 825. I'm local 11 IW. [emoji106]
