Leveling kit install?
RedRamIt
Wichita, Ks
5.9L 360ci V8 Magnum
Okay, so I ordered a 2 inch leveling kit today, consisting of front coil spacers for my 98 2wd 1500, was wondering how much trouble am I going to have to through installing these? Are there any shortcuts? Am I going to have to rent a coil spring compressor? I've never messed with spacers before.
Link to spacers I bought
HemiBabe
DFW
From what I read you just have to jack up the truck enough to remove the weigh off the springs and pry them in, but maybe someone will have better advice lol
RedRamIt
RedRamIt
Wichita, Ks
I'm hoping someone will before they're delivered and I have to actually follow the instructions!
Tapatalk
quietpeen
2021 TRX
Hellcat
Tapatalk
lol cause men don't read instructions or ask for directions :birgits_tiredcoffee
LilRamMan
Haslet Texas
I am planning on ordering a leveling kit for my 95 1500 so I'd be interested to see what all the install entails...
RedRamIt
RedRamIt
Wichita, Ks
Well..ill let you know after I read the instructions when mine comes. Lol. Nobody here knows and if they do they aren't talkin!
Tapatalk
reddot
Wolf Point, MT
5.9 cummins
one of the guys with lowered truck may be of more help since they deal more with 2wd truck. the 4x4s are easy but that all I know anything about. Good luck with the install. Get new shocks with those spacers?
RedRamIt
RedRamIt
Wichita, Ks
No new shocks, old ones are still good..newer than the truck but Idk what brand and the paycheck only allows one item at a time Haha
Tapatalk
reddot
Wolf Point, MT
5.9 cummins
well consider if your lifting the truck the shocks dont extend that far at least under X amount of suspension drop. Might get a rough ride and some a very short shock life. just saying.
RedRamIt
RedRamIt
Wichita, Ks
Yeah when these shocks go out ill replace em. Lol
Tapatalk
the codes
Houston, Tx
Magnum 5.2
I have a 2" level waiting to be installed to. gotta get my shocks first though.
as far as I can tell, jack the truck up, support the end of the axle because you have to release the upper control arm and it will drop if not supported and you will bust brake lines. then just take the coils out and put them back in with the spacers and button it all back up. some people have said they can just pull the springs out and others use the compressor tool.
Tapatalk Addict
RedRamIt
RedRamIt
Wichita, Ks
Alright man thanks appreciate the help
Tapatalk
RedRamIt
RedRamIt
Wichita, Ks
reddot..what shocks do you recommend??
man n black
Cummins
Bilstien 5100's. Did wonders for my 2500 on 2 inch coil spacers.
Ch
Sent from my DROID RAZR using Tapatalk 2
the codes
Houston, Tx
Magnum 5.2
Ch
this is what I plan on doing, I just need to call bilstein and see what part number is 2" longer then stock shocks.
Tapatalk Addict
RedRamIt
RedRamIt
Wichita, Ks
Tapatalk Addict
When you find out, let me know man..Would be much appreciated.
the codes
Houston, Tx
Magnum 5.2
I would think so, the whole 4wd thing though Im not sure about since we have 2wd trucks.
Other then that..looks pretty good.
stevenmicheal
