leveling kit question
ryan8301
I have a 2012 Dodge Ram 1500 quad cab 4x4. I just recently bought a 3" leveling kit and a set of 20x9 wheels with a 15mm offset. I'm wondering if 33's will fit on it or do I need to run spacers. if I need spacers what size do I need?
MADDOG
Living in a Firepit
What is the section width measurement of the 33's?
R
ryan8301
here is the description its reading
Size
33/12.5/20
Load Rating
114
Speed Rating
Q
Max Load /Pressure
2600@65
Tread Depth 1/32"
21
Inflated Diameter
32.8
Inflated Width
12.3
Revs Per Mile
Tire UTQG Rating
Approved Rim Widths
9.5-10.5
Load Index
E
Ply Count
10
Sidewall
BW
DannyMK2
Long Island, NY
2015 Power Wagon
3" leveling kit is too much. i wouldnt install it. the tires will probably rub a little bit, but it depends on the tire.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
As DannyMK2 said, a 3" (I assume spacer) leveling kit is too much for the stock front end. I wouldn't recommend installing it; you'd be far better off with Bilsteins at 2.8".
The 20x9 +15 offset wheels won't give you enough clearance on the suspension components to run 12.5 wide tires. You'll need 10mm hub centric spacers from Motorsport Tech at a minimum.
R
ryan8301
How much of a leveling kit should I be running then? I looked up the Bilsteins but there is a few different ones. Which ones should I get?
