Licensed ATF+4 Brands
2013 black Crew Cab Express
Guys
Here is a link if you are thinking about changing your tranny fluid. Hopefully it helps you. If you click on About ATF+4 on right side it states that ATF+4® is a high performance, synthetic fluid. It may save you some bucks if your thinking about buying synthetic fluid. Here is the link.
Bob
Licensed ATF+4 Brands | Chrysler
:favorites13:
hemihustlin
Lower Southwest Quebec
Pretty sure redline and amsoil make atf that works in our trannys though, some people on here use those as well with no problems as far as i know.
jlb
MT
CTD
I use Redline with no problems. Love it actually.
A lack of licensing does not always correlate to an incompatible fluid. Licensing can be incredibly expensive, and fluids that meet or exceed manufacturer requirements often exist that are not licensed. As mentioned by hemihustlin Redline is a perfect example of a high performance, high quality fluid that far exceeds the Mopar specifications for ATF+4, but is not licensed.
Licensing is one way manufacturers can control whose fluids will be purchased for their vehicles, and also provides them with some extra income on the side if people choose to use something other than factory fill fluids for their vehicles. I am certainly not advocating you run out, and just dump any old fluid in your transmission, just be aware that more choices are available than just the "licensed fluids."
