Lift and sifting issues
Buckeye2019
2018 Cummins
2015 express 5.7 8speed trany 2 wheels drive. So after putting on the lift 7inch max tracks also 20x12.5 toyo tires. When I'm on the highway if it's flat it's ok othe then that it's shifting back in forth from 8 to 7th gear. So do I need a different gear set up? Would a tunner take care of the problem?
Jershipe
Monroe Michigan
Did you get the speedometer recalibrated for the tire size? Makes a big difference in the shifting.
Buckeye2019
Buckeye2019
2018 Cummins
No I didn't. How and where would I get this done at?
Jershipe
Monroe Michigan
I bought a used diablosport tuner. Was about 200$. Think you can buy just speedometer recalibration programmer. But I wanted to tune mine and turn off the mds anyway. So that was the best bang for my buck.
Buckeye2019
Buckeye2019
2018 Cummins
I will have to ask my dealer if he can do that on my next oil change.
Buckeye2019
Buckeye2019
2018 Cummins
Can someone tell me what the dealer can do cause I called mine today and he said they can't flash the computer for bigger tires sizes.
Jershipe
Monroe Michigan
Think it depends on the dealer. Seems like some dealers will and some of them suck.
Buckeye2019
Buckeye2019
2018 Cummins
Hpstang thanks I called my dealer and explained to them and now I have appointment nexted weekend.
Ferro
I had the dealer do mine.
Buckeye2019
Buckeye2019
2018 Cummins
Gerri was there a difference in the sifting of the truck?
Schmittj22
New Jersey
Buckeye, I had the same issue. I am running 4 inch lift, bilsteins at 2.1, and 35s. Your higher and wider so I am sure you are having issues.
Only way to recalibrate on a 2015-2016 is too get a diablo tuner. But with this you will need a DCX PCM or send your pcm in ($1200 new). I was lucking to have bought mine used for $650.
I just got a hemifever 91 oct tune and its amazing. averaging 17.1 mpg and acceleration and shifting is much improved.
Buckeye2019
Buckeye2019
2018 Cummins
I have 35 12.5 on a 20 inch fuel. I did call the dealer and they said they can go in and flash the ECM to accommodate for the bigger tires
Buckeye2019
Buckeye2019
2018 Cummins
Well y'all I went and got my free oil change for life today and they flashed the computer for me for free. So I just wanted to say thanks for everyone who let me know about this. The truck is like it was before I installed the lift. No more issues with shifting and it even drove great in ecomode.
pkillian
