Lift help confused
erice
2013 ram 1500 slt
I asked a while back but need tires now big time
I did the rancho lift and level kit and need to do rims and tire
Told at 4x4 shops I can’t do 35” on 20
But my understanding I can do 35x12.5 bf Goodrich ko2
And do a 9x20” rim
I wanted to order them early this week just don’t want to f up
Can somebody show with the 35” on with level lift kit do the tires rub at all not going off roading with this truck
Thanks
joeygster
Ancaster, Ontario
I'm running 35's on 20x9 Rockstar 2 rims with a -12mm offset.
You can even run the OEM 20x9 rims with the 19.05mm offset as long as you have spacers.
erice
erice
2013 ram 1500 slt
2013 ram 1500 Ext cab slt 4x4
Don’t want any spacers no time getting snow tomorrow 20x9 needs -12 offset on 20x10 with no spacer and no rubbing at all
Thanks trying to get today to tomorrow
joeygster
Ancaster, Ontario
20x9's with a -12mm offset will work.
Someone else can comment on 20x10's because I have no idea.
erice
erice
2013 ram 1500 slt
Thx
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I had 285/65/20, roughly 34.5" tall, on a leveled 20x9 with 0 offset.
erice
erice
2013 ram 1500 slt
But being safe I should get a off set will it stick out of wheel well
Does it matter the tire brand
