lift kit problem?
skip4346
Hi everyone, I am hoping that someone might have an answer for me on a problem that has occurred probably 3 or 4 times in the last 8 months.
This has occurred at highway speeds every time and it has only happened when there is a dip in the road, one that makes your suspension compress on all four corners if that makes sense. So the problem is, for some reason that is causing my electronic stability control to activate (I think) as my truck seems to brake and I lose power at the pedal for about a second or two. It hasn't happened on bumping roads or city driving.
Here is the set up I have: Superlift 4" lift, 35" tires (these are bead balanced...could that be the problem).
Any help or advice would be great. Thank you in advance.
Westwind1124a
Maine
2024 ZR2Hd
6.6 Duramax
I don't have an answer for that, but I do have one storm drain that if I'm not careful and hit will cause the traction control to come on. The truck makes a buzzing noise and I lose gas pedal authority. seem strange that you'd hit anything that hard on the highway though. When it happens to me I think the front left tire loses contact with the road.
S
skip4346
Yes, it is the strangest thing that I can't seem to find an answer on. Im going to the tire shop to get rid of the beads and go to weights to see if that may correct things. Probably not, but worth the try.
geneseedennis
