Lift spindles installed... Finally
bloombloom88
Plano, Texas
Still in the process if wrapping things up in the shop but these are the pics I have so far
The lift spindles are about 15 pounds heavier than the factory ones
Ill post more pics when I'm done with the alignment
bloombloom88
bloombloom88
Plano, Texas
Completely level now. I know this sounds crazy, but the truck actually rides a little smoother now than it did before. Can anybody explain this?
sausec17
Banned
ATLANTA
HELLLLLL YESSS!! So much better than using cheap ass spacers :)
looks good brother
sausec17
Banned
ATLANTA
might ride better because of the wider stance? better handling
bloombloom88
bloombloom88
Plano, Texas
Haha thanks bro. Actually, these spindles didn't push the wheels out at all.. I was kinda disappointed
sausec17
Banned
ATLANTA
what? seriously!?
all the lift spindles that i have seen ALWAYS push out the tires at least 1"
I might go this route then, prevents using 1.5" wheel spacers on the rears to match the front
bloombloom88
bloombloom88
Plano, Texas
Yeah at least the front and rear wheels will be evenly spaced out this way
sausec17
Banned
ATLANTA
true that, well it looks good brother and helps maintain a factory ride. no bad angles, bad joints, etc. compared to spacers. always a better choice!
bloombloom88
bloombloom88
Plano, Texas
Indeed sir. Ill end up doing 2 inch spacers once I get the new tires. Then a 1.5 inch body lift. At some point new upper arms with stronger joints
sausec17
Banned
ATLANTA
nice! what size tires?
my next step is a 3" bodylift, so Ill be at 7" front & 4.5" rear. Im gonna try to run 37s. If not, I can add coil spacers to both front and back until i can clear them
bloombloom88
bloombloom88
Plano, Texas
35s for me. I'm avoiding the 3 inch body because.. Well.. It only lifts the body lol. Being 2wd I want to gain as much ground clearance as possible
Appauldd
2012 Ram Big Horn
Can you please tell us all where you got the spindles from?
Thank you.
Appauldd
2012 Ram Big Horn
Awwww. Darn! Looks like they only work on 2WD.
Oh well.
Appauldd
2012 Ram Big Horn
Guess I need to drop some coin on the Bilsteins.
I have spacers and now my front shocks squeak like rabid chipmunks any time I drive over semi rough roads.
bloombloom88
bloombloom88
Plano, Texas
Yeah, your shocks aren't too happy right now lol
Kmiko
