Gents,
Thanks for the wealth of collective wisdom in these forums. I'm getting ready to lift my 2014 Ram 1500 and get rid of the factory tires (which are the worst tires known to man). I work on my own vehicles, but I'm a total ****** when it comes to upgrading a truck. I have searched the forums and found a bunch of solid info scattered around. I just need you fine people to make sure I am not off track.
I want to lift the truck a bit (around 2 inches) and keep the factory rake since I do tow/haul a bit. I also want to get some larger tires (wider tread and bigger sidewall for off-roading). I don't really want to mess with spacers or offset or anything like that. Baby steps! Based on what I have read in the forums, my plan is to:
1. Install Adjustable Bil 5100s in the front and raise it up about 2 inches.
2. Install Bil 5100s in the rear (totally optional, I understand), with a 2 inch spacer to keep most of the factory rake.
3. I have factory 20" rims (factory tire is 275/60R20). I *THINK* I can upgrade to 285/65R20 (approx. 34.5 diameter) and not rub and not need spacers or anything special. They will be AT tires. If I have to choose between a taller or wider tire, I would choose taller just so the wheel well doesn’t look empty. Will this fit or will I be rubbing?
Am I going down the right track with this or am I completely off the reservation? Besides the 2-3mph speedo difference and the fuel economy from the lift, am I going to notice any other difference or change? What am I missing? On behalf of all noobs everywhere, thank you.
