Looking for transfer case shifter bushings
PaulTGarrett
Grumpy old man
Tampa Bay, Florida
408 Cummins Turbo Diesel
I'm trying to find the rubber bushings for my transfer case shifter and was wanting to support you for supporting the Forum!
2012 RAM 2500, 408 CTD, auto transmission, manual floor shift transfer case
Thanks for the help!
AllMoparParts.com
- Benny
Supporting Member Supporting Vendor
All
All
Hi Paul,
Thanks for your inquiry. Can you message me your VIN please as I need to sort out which transfer case you have.
Thanks!
- Benny
PaulTGarrett
PaulTGarrett
Grumpy old man
Tampa Bay, Florida
Hi Paul,
Thanks!
- Benny
Hi Benny,
My VIN is 3C6UD5HL5CG100927 which the "VIN Decoder" shows me having an NV271. I'll need both bushings, one is kinda sorta still there, the other is gone. LOL
Thanks!
Paul
AllMoparParts.com
- Benny
All
All
Thanks Paul,
You are correct NVG271 however there does not seem to be any serviceable bushings available. See the attached doc for all available components. I think your gonna need the shifter assembly pictured below
- Benny
  • Shifter.pdf
PaulTGarrett
PaulTGarrett
Grumpy old man
Tampa Bay, Florida
Thanks, Benny!
But since I need both bushings does that mean I would have to buy the transfer case shift lever, too? Buy both levers just to get the bushings? That's a bit on the outside. I know you're going to tell me yes, though. I went through the same thing with my '98's window regulator. Rollers went bad, couldn't buy just them for a buck a piece, had to buy the whole $250 regulator.
Ah well, I certainly do appreciate your time and effort to look that up for me! Guess I'll have to check around for a more "home brewed" solution.
Thanks!
P
AllMoparParts.com
- Benny
All
All
Thanks, Benny!
Thanks!
P
Hi Paul,
You are correct and I just came across these notes from FCA which confirm it as well:
For grommet (bushing) at transfer case, order p/n 5080227AA lever. For grommet at shifter, must order shifter p/n 52105551AB.
Please let me know if you have any other questions.
Thanks,
-Benny
Kmiko
