68Malibu383
- Apr 18, 2015
- 145
- 67
- 2015
- 426
Getting ready to replace my 240K mile 2005 Chevy with a V-6, 8spd crew cab RAM. Have a few questions before I pull the trigger.
I read that the 2015 has a transmission warm up feature that uses engine coolant to warm the trans fluid (this will reduce viscosity quicker and helps fuel economy). I wanted to know if there is a way to bypass this (guessing with a programmer)? I've always installed a large external transmission cooler on my cars/trucks that will keep my fluid temps around 150 degrees. This helps the trans live a long life because heat kills automatics (I've never had a transmission problem and I put a ton of miles on my vehicles). I'd be fine with the trans warming up quickly, but once it does, I want the fluid to go through an external cooler, then back to the trans.
Is the 8 speed trans behind the V-6 the same as what the V-8 trucks use? How about the Ecodiesel? Just curious since if it will hold up behind the higher powered trucks, it should live a long time with a V-6.
Wondering if it is a good idea, for gas mileage, to run the 20" wheels/factory tires with the 3.21 rear gears. All of the 20" wheel trucks I've seen have the 3.55 gears. The 3.55s and 20" will turn the engine about 100 RPM higher on the highway over the 20" with 3.21s. The advantage of the 3.55s may be that the truck does not downshift as much trying to maintain speed.
Thanks for any advice!
