Looking to install some subs n my truck.
Smallblock421
Lexington ky
Looking to add my subs to the sound system
Does any one have 2 12's under the back seat. I would like some feed back on how they sound, And what box did they use. I have 2 Jlo w3. And i would like to use them but if I can't i will switch to 2 10s. Thanks for any help.
Power247
High Point, NC
6.4 HEMI
12's will sound great but fitting boxes with enough airspace under the rear seats is really tough. Check out net audio or fox acoustics to see if the offer a box with enough airspace for you sub's. If they do then you should be good to go.
Little Red
NY, USA
Pretty sure you'd need to build a custom enclosure to get the air space you're going to need. You can fit 12's under the backseat, you just need to measure properly, and space the seat up accordingly for clearance.
doz
Sealed enclosure he will be fine for most 12". Ported w/ 12" might be a bit tougher.
Arturo Rojas
