Losing oil
LDBagger17
Central Pa.
Have a 2012 1500 5.7, recently had cam installed, heads freshened up, hellcat lifters, and oil pump. Got a custom tune. Losing oil, lost over a quart in first 1k miles. Found oil leak at front crank seal and had drips at bottom of bell housing. Had new front seal put in and oil pan retightened. Still damp at bell housing but no drips, oil level is still dropping. Has a 6.4 manifold on it so can't use a catch can, no smoke, runs good, leak down was done on engine once heads were bolted back on and all tested between 86 & 91. Does anybody have any ideas. Thanks
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Maybe they didn't do a decent job on valve seal guides.
Take a look at 1 of the spark plugs.
Dodge 1500 4X4
Rochester, NY
Is the lower end original did you do a compression test, and how do the plugs look
LDBagger17
LDBagger17
Central Pa.
Bottom end hasn't been touched other than oil pump, timing chain, guides, gaskets. Plugs look good.
crackerjack1957
If its not leaking oil it's got to be burning it in the combustion chamber......no other place for it to go except the coolant system.
Dan98
Possible oil leak from back of intake
Sent from my SM-J260A using Tapatalk
NJMOPAR
Older and faster
ELizabeth, NJ
When you return the heads to new condition and don't do the piston rings, guess what happens?
The old oil rings can't hold the new pressure so oil gets past.
Had this with a 68 Chevelle decades ago, blew a quart past the rings in the first 25 miles.
Expensive lesson learned in my youth.
savage_46
Alaska
6.4 swapped
Pcv missing an o-ring? I've seen that once & the engine was drinking oil
