Lost Wheel lock key
CC12RamLove
Escondido CA
Dont know how it happened. I lost the key to my wheel locks. Dealer says $65 for a matching key and set of nuts. Anyone know how to get theses off with out it?
Sent from my SM-N920P using Tapatalk
Rlaf75
East Hartford CT
2021 Bighorn
Dealers should have a master key/tool to remove them. They may charge you to remove them.
avantiguy
Bay City, Mi
hemi
Not sure if the OEM wheel locks have a slipping collar
My 2014 OEM Mopar locks have the spinning collar and the PO apparently lost the key. I tried the drive a socket on method and it failed. Just can't compress the rotating shell enough. Tomorrow, I'll cut the shell off with a high speed wheel and then use the socket method.
I purchased another set of the Mopar/Mcgard ones like the originals and will replace them. I ordered a second key from Mcgard and will keep the key numbers.
I also registered the key with Mcgard and they will now have a permanent record of the key for reorder.
Bob
dhay13
most tire shops have a universal 'tool' to get those off. i took mine off and left them off
CC12RamLove
CC12RamLove
Escondido CA
I guess i will have to take it to a shop and see what they can do. They have a slip collar and the socket method didn't work.
Agcat
