Yeret
Professional Procrastinator
- Oct 2, 2014
- 1,001
- 212
- 1999
- 5.9 Magnum
Okay, this is an annoying issue that I've had since i've owned the truck. Basically, if my steering wheel is in a lowered position, the low beams will flicker off and on randomly especially over bumps. If I raise the steering wheel, I have no problem at all. Since this "solution" has been working, I haven't proceeded thus far, but it feels like I'm driving a school bus with the wheel up like that and it's high time to address it.
Now, this problem ONLY affects the low beams. If I use the high beams, they stay on no problem irregardless of where I have the steering wheel.
I poked through the electrical diagrams in my Chiltons a while back and seem to recall there being separate grounds for the low/high beams in the multi-function switch, which would certainly explain why only my lows are affected and why the wheel position causes the problem to begin with. Does a bad ground seem like a good place to start?
