Low Beams Stopped Working
roadkingrider_200
NH
I have a 2017 Ram 2500. Both low beams stopped working. I’m guessing a fuse or relay. Has anyone else had this happen. If so could you please assist me with the issue. Thank you.
Daw14
South Florida
Sounds like maybe a dealer fix for you ,the fuses are under the hood.on the lid inside of fuse box are labels as to what goes where.
mtnrider
Georgia
I don't have wiring diagrams for a 1500 but assume they are pretty much the same as a 2500. With that said, there is no fuse for the low beams, the lights are controlled trough the BCM (the BCM is fused but you would have several things out if that was blown).
Do your high beams still work? If no I might suspect the headlight switch, if they do it could be the BCM?
turkeybird56
Central Texas
YUP, headlights thru BCM, unfortunately
