Low Resistance Spark Plugs
FytKid
Houston, TX
I'm trying to hunt down low resistance spark plugs that are 500 ohm rather than the oem 5k ohm. I would even like to find zero resistance spark plugs. The problem I'm having is that when I look or search, I only get results for 5k ohm coils. I want to find the same size spark plug at lower resistance, but I don't know of an easy way to hunt them down. Isn't there a spark plug finder by specs? Reach length, thread type, taper or no taper, resistance etc...?
Hard to find non resistor plugs anymore.Try reseaching non resistor or low resistance racing plugs,you might find something in the racing world,but even that might be a stretch now-a-days
RamDiver
Marlborough, Ontario Canada
2021 DS
Are you having ideas about installing non-resistive plugs into your Ram truck?
