16RamHemi
- Feb 2, 2016
- 924
- 1,314
- Location
- Western Maine
- 2014
- Hemi 5.7 Sport Crew
Hey guys, i have a 14 1500 5.7 with the 8 speed 8hp70 trans. I have a low rpm slip that i cannot find any information or like symptoms. Its like slipping or riding the clutch in a manual. From a stop in first it does not do it. It is mostly when slowing down then getting back on the gas. it will slip up to about 1700 rpms then come back to 1500 and "engage/go". I can feel the truck "engage", its not violent or harsh, very light but can be felt. If the engine is tacked up it wont do it. I try to keep rpms up to avoid it or feather the throttle easily getting going. Other than that i dont have any issues (no issues going into any gear up/down, no slip when down shifting etc). I manually shift most of the time to keep out of low rpm situations. But sometimes it cannot be avoided.
Any ideas what would cause this? Solenoids? i do not have a trustworthy transmission place around me. especially one that will be experienced with these 8 speeds. I changed the trans fluid this summer (fluid level was correct). Truck has done this prior to fluid swap. Has not gotten worse, its very consistent. Will do it every time at low rpm.
