Low Speed Vibration, Mid Speed Noise and High Speed Calmish
Joesdog
Richmond va
Hey there! I have a 2004, 4.7, regular cab, long bed 4WD. I just installed a rebuilt engine. It sat still for 2 years. The issue I’m having is from 25-45mph, I experience a strong vibration. From 45-60mph, I have a rocking tire kind of noise. Above 60mph, noise disappears and vibration is reduced to minimal. To say the least, I’m a bit perplexed. I know that low speed vibration could be a seized U-joint. Any thoughts about this are welcome as well as appreciated.
phunahm
Ive done pretty much all that rear axle are new bearings .... RH front new bearing and cv LH are original but vibration/nose seems to come from RH side even a passenger said the it can be felt at her feet.....
06 Dodge
Forest Grove, Oregon/soon Osage Iowa
6.7L CTD
Sounds like you need to take it to be looked at... When I changed front axel joints on my 06 I had both changed at the same time, I don't like the idea the old may go out at any time when on a road trip and need a costly tow to the nearest shop...
ChloeBrooks
