Lowering truck advice on tire size
Darth Vader
Woodstock
I want to to do a 2/4 drop on my 2014 ram 1500 sport crew cab 2wd. I’ve decided on the Mcgaughny’s 2/4 deluxe kit. My current set up for wheels and tires are 22x10 hell cat replicas with Nitto 305/45/22 tires. Does anyone know if this setup will work in combination with this kit.
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
You should be able to run those with a 2/4 drop. Any lower and you would want to rethink tire size
Mike Townsend
I have Viper reps in that size with the same tire size on a 2/4 drop on my 2014 R/T SC
D
Darth Vader
Woodstock
I’ve always had slight rub on the right fender liner when full lock on left turn but not enough to damage. This at stock height.Have you had any issues with 2/4 drop?
D
Darth Vader
Woodstock
Thanks for the help. I definitely feel better about this project.
TMFMK
