lug nuts .
PaPitt
Stephenville TEXAS 76401
5.9L
SO I bought a set of Chrome wheels & big tires .. Wheels are 2002 I believe .& I'm putting them on my 1988 Dodge D250
... 1988 USES 1/2 LUG STUDS . & 2002 USED 9/16.
WHEELS GO ON FINE . BUT With the 1988 lug bolt which will hold the wheels on & in place centered .. fine ..
..... But the Dodge center caps won't afix to the lug nuts .
... So what do I need to do..
Where can I find some center caps that'll work on my rig.
Or Can I buy some special LUG NUTS .
... Or can I buy a different center cap.
.... I CAN SEE THE Flat rear axle cover that goes on before the
WHEEL IS MOUNTED.
.... bUT WHAT CAN i USE ON THE FRONT WHEELS .
P
PaPitt
5.9L
SO I get this message from you Guys . saying you've move my post above . That's fine it needs to be in the best location to get more frontage..
But how do I know where you've move it to .
I've had several moved & I've not found any of the again .
THANKS .
P
PaPitt
5.9L
OK SO MONTHS LATER BUT I found some center caps for my truck . They were Phoenix Chrome plastic caps . $15.00 each . QT765C . they fit over the lug nuts & you just slap them real hard . Man my wheels look great now .
