M² Mods Intro & Project List
redintex
Central Texas
3.6 V6
i need to order a 911 plug from you, please. I also have a question about updating my firmware. I did the 8.4 conversion roughly 5 years ago on my '13 Ram 1500 SLT. I bought the 8.4 radio from LKQ, and while they said it was from a '15 Ram, I recall having problems trying to update it. As I recall, I believe I found that it came from a 15 Jeep Cherokee or Grand Cherokee. I am showing to have Software version 13.44.0. My latest map database shows as 20130926. Any suggestions on how to proceed? I definitely don't want to brick it, but I do have the crazy nav issues I have seen discussed here. Thanks for any guidance!
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
What's the exact PN on the back of the radio? (ie 68238619Ax)
If it matches one of the ones listed in the OP of the following update thread, you should be able to use the related update....
INFO - 2013-2017 8.4AN FW Notes (RA4/VP4 NA).
M² Mods.
Joe Adams
Owensboro, ky
I asked that if you would make my fog light harness, I also need the 911 fix for my 8.4 radio
this is the number on the radio 68238621AF
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
This is Joe email is. ...
Joe, please remove your personal email info from the post above... and just remail me what to need some up already have my contact info. Will have your fog light harness ready later tonight.
M² Mods.
HeavyG603
Free Republic
Hi everyone!
Deereguy and I decided to start a little side project to help out our fellow members with various wiring harnesses and mods for some of the smaller projects and threads around the 4th Gen section for our 2013-2018 trucks.
Each of us will be focusing on specific projects as listed in the next 4-5 posts.
We are calling our joint venture: M² Mods
For now, contact us via Private Message (pm)/conversation so we can give you our contact info with all the details (click our user profile picture). Thank you in advance.
M² Mods
Mpgrimm2 (Mike G.) & Deereguy (Mike D.)
------------ ORDER UPDATES/ETAs -----------
Side note: ** DeereGuy got promoted at his day job and will only be offering the Obd Bypass Harness and UAQ USB Hub Adapter harness once he runs out of heated seat and Cargo Cam harness parts. See DeereGuy Status.
Disclaimer:
Performing these or any modifications to your truck could void your manufacturer's warranty and/or cause issues with the function of the truck. By purchasing and/or installing any of these custom items (harness, bypass plugs, etc) you agree to absolv M² Mods, Mpgrimm2, Deereguy, and all associates of any and all damages that may occur as a result of installing said item. If you do not agree to this provision, please do not purchase and/or promptly return the item(s) for a full refund (less 15% shipping/restock fee). Additionally, we reserve the right to refuse/cancel an order at our discretion.
This is awesome work you guys do, you are fulfilling some big holes left by Ram in their options. I’m trying to find a way to tap into my backup camera wiring in my 2020 3500 Tradesman when I use my tailgate sander in the winter since it’s blocked when that thing is on.
jimlmackjr
Harker Height, TX
Quick question
I have a Express didn't have Fog lights but my offroad bumper had them and I installed a light switch with factory fog light button.
So we'll the fog light harness just plug in and make the switch work.
Than just Alphaobd to activate it
And can I get a harness for powerseats
And the 110 dash plug
TylerC
Alberta, Canada
You Fella's seem to be the wiring guru's on here :) .
I have a pretty big project on hand - swapping the entire sport interior into an ST RCSB. 2014-2014 both trucks.
The dash i have came complete with the wiring harness, i also have the mirror and overhead console and i have the complete harness from the CC donor from the 3rd brake light to the fuse box
Should the Dash and Overhead console be pretty much plug and play as they are from the same truck?
I do have the Alpha OBD to enable things when i get it wired and have a new RF Hub for the remote start- keyless entry mod.
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Responded in the other thread.
M² Mods.
jimlmackjr
Harker Height, TX
Quick question
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Quick question
I'll send you a message to get things started.
M² Mods.
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Just an update...
I won't be taking any new orders until 8/7/20
Had a bunch of orders come in this past week and I don't want to give folks excessive ETA's. (I think I've covered everyone that's messaged me recently)
Will try and answer any questions in the meantime. Thanks again everyone for the support!
Mike G.
M² Mods.
Mohh
canada
Hi
How do i purchase the Base to 8.4 Radio Conversion Harness (7 speed Fan specific models)?
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Kdbl007
Seattle
Are you taking orders for fog light jumper harness?? 2011 2500 SLT. I’ve got a 2 wire plug coming off my headlight harness at the drivers side (dummy plugged currently) but the factory fog light wiring kit I bought has a 4 wire plug. Guess I need the jumper or.....??? New to Rams.
side note...I replaced the non fog light bumper to one with cutouts and got a factory headlight switch with the fog light option. I do know I’ll have to “turn them on” in the bcm which will be done with AlfaObd.
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Message sent
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Coming soon....
True universal 8.4 primary conversion harness (v4)... with:
- 4spd/7spd support in same harness
>> Just add our plug n play fan harness for 2500/3500 4 speed fan trucks
- Single Zone ATC part 1 built in
>> Just add our ATC part 2 harness if needed (for 14+ 1500's/classic)
- Support for Dual Zone ATC ... For those wanting to add extra blend door.
>> Will have to custom build rest of blend door wiring into add-on harness
Will be same price as current harness with ATC Pt1 built in.
Also coming soon ....
2017-19/20classic Mic Headliner & Compass module harness
(Sent out today for test install)
- will allow adding factory mics in headliner (vs 13-16 mirror mic reroute done previously)
- Compass module wiring Support
(No overhead lighting, power rear window)c1f3949fb2ad8a4a92fba00f376501b9.jpg
M² Mods.
RaptorHD
South Carolina
2019 2500HD
I have a 5th gen Ram 2500HD, my ram has the 8.4 and I have the tailgate backup cam,,I would like to install a cargo camera,, I just purchased the 3rd brake light but need the harness to the radio.. Do you make this?
Lastly I was wanting to install the roof clearance lights,,need a harness for that too..
Thanks!
