major misfire no 7 help please
snowhemi
Sandpoint Idaho
So here is what is going on.
Have a 2009 1500 with 5.7 hemi.
Truck is misfiring so badly it shakes the truck while doing it. Only code is a p0307 every time.
If rpms are high like 5k its not notable. Til drops down and MDS kicks in at 1400 doing 60.
I changed plugs. Swapped coils swapped the injector. I have ran 89 octane minimum.
I have put a bottle of seafoam in throttle body over a few hour time before new plugs.
I have .25 of a quart of marvel mystery oil in oil. I have ran 2 quarts in gas. I pulled the valve covers no visible damage to springs but new plugs in number 7 are black. Cylinder is clean with my camera scope. Did a compression test on 7 and its at 215psi and holds it there.
Also sprayed carb cleaner and brake kleen around intake and head gaskets with no idle change.
Tester broke before could compare with another cylinder. All this and can't figure it out. Willing to try any and all suggestions. Thanks in advance.
japowell03
Only thing left I can think of is checking for power at the injector. Should be always hot, I'm pretty sure the ecu switches the ground side off and on to actuate it. How did those injector seals look? Checked vacuum lines already? I would pull the valve cover and watch as someone turns the crank a few times. Most of this doesn't make sense either because you have a black plug and good compression...
S
snowhemi
Sandpoint Idaho
Set ohms to 200 or another setting? Seals looked great. Put a little oil on when put back together. Truck has 72800 I bought with 61500.
TylerB
FL
Have tried moving the coil pack to a different cylinder to see if follows that coil?
NYCruiser
Yonkers, NY
Sounds stupid, but have you changed the plug wires to #7? You didn't mention it.
Figures it would be the one under the brake booster.
S
snowhemi
Sandpoint Idaho
Correct. No metal. I put in synthetic cause did not know what it had in there. And was 4 miles from my work shop to change oil when this started.
S
snowhemi
Sandpoint Idaho
Yes I moved the coil. Tested the coil and it is .6 so in spec. No vaccum leaks.
japowell03
Set it for vdc should have power at the injector plug with they key on. I'm not positive it will on these trucks though, so verify whatever you find with another one. Use a chassis ground not the negative in the plug.
PaxtonScarborough
Either there's no voltage to the coil or injector, or the PCM isn't controlling one of them properly, also could be a wire chewed or frayed.
B-g-K
Upstate NY
Ecodiesel
I'm sure you've checked all your grounds already right?
S
snowhemi
Sandpoint Idaho
I'll do that tomorrow. Thanks y'all.
What is the proper way to test power to the coil? I tried once with no luck. My issue comes and goes :/ if it is mechanical I'd have warranty they want 100 per hour to do what I have been doing if they find no issues. Like me. :(
japowell03
Yeh could put a plug in the coil removed but plugged in, and try to spark it against something metal and unpainted. Have someone start the truck, wear a glove (dry) or it will zap you pretty good. If that works and you have voltage at the injector safe bet it's the PCM.
S
snowhemi
Sandpoint Idaho
I'm sure you've checked all your grounds already right?[/QUOTE
Ya I have. At least I believe all grounds.]
One ground strap nobody talks about anyplace I seen underneath the tranny on the cross member for the tail shaft there is a strap and I have no clue where that clip clips on at. I see no worn spots. I know not related to my issue but ideas?
S
snowhemi
Sandpoint Idaho
Easy enough. Just like if it had wires.
japowell03
Pull that valve cover and take a look. Springs could be good but still could be a bent pushrod bent valve or collapsed lifter. See if the rods have any play.turn it over by hand and watch the rocker arms going up and down. Not much left to look at. Pull the radiator cap and start the motor.see if it it's blowing bubbles...
S
snowhemi
Sandpoint Idaho
I'll pull the cover again. Getting good at it. Haha
Bubbles indicate what exactly? Cracked head? Tore gasket?
S
snowhemi
Sandpoint Idaho
It comes and goes sometimes. If in neutral it will not misfire. If I power brake it it will at 1500 if held for 45 seconds.
japowell03
It will show you a failed head gasket sometimes.they fail in different ways a shop can do a full leak down test on that cylinder and give you a lot of good info a regular compression check wont.
