Map lights turn on when turning up dash cluster lights
VinceOB
Atlanta, GA
So I have a 2003 Ram and noticed when turning the dash lights on the map lights turn on, but when I turn the dimmer down the map lights turn off. I don't know what else to check. Anybody have any idea as to why it's doing this?
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
there's usually a point the dash light control turns on the interior lights. Maybe your knob has the point worn down that would tell you where to stop turning up the dial.
VinceOB
VinceOB
Atlanta, GA
Yea I think I know what you're talking about. Unfortunately, I don't think that's the case. I hear that pop when it's supposed to be on. When I turn the cluster lights off the map lights go off. When I dial it up the first pop the map lights come on. It stays on even after I turn the truck off. Very weird. I checked fuses, but I'm not sure I checked the right ones.
shadowhawk
Southeast WI
that sounds like a switch issue, not a fuse issue
shadowhawk
Southeast WI
I'd say the dash/map light switch.
VinceOB
VinceOB
Atlanta, GA
I swapped out the switch and it still didn't work. I don't know what else it could be. Any more suggestions?
IRSmart
I drink and I know things
Westminster, MD
2018 Power Wagon
6.4L Hemi
This sounds like a silly suggestion, but are the map lights on at the light? Meaning, did you press them and turn them on? If they were on, they would be exhibiting the behavior you are experiencing.
VinceOB
VinceOB
Atlanta, GA
Haha I know what youre thinking, but no, the lights arent on at the map light. Its a weird issue im having. Question for you though, do you post on Mdub? LOL
IRSmart
Westminster, MD
2018 Power Wagon
6.4L Hemi
Maybe...
VinceOB
VinceOB
Atlanta, GA
Ok so here is what happens, I swapped out the headlight switch and it worked at first. I was able to turn up the dash lights without the map lights coming on. Then I turned off the truck. When I turned on the lights the map lights came on. So I turned the dash lights all the way down to turn them off. Then a little while later I tried turning up the dash lights and the map lights stayed off. So weird. Not sure what else to look at.
Edit. I see what's happening. When it works it's good till I shut the truck off. When I turn it back on is when the lights go on. When I shut it off at the switch it's fine. When I turn back on truck and put dash lights on the lights don't come on.
HemiLonestar
Navy Badge Coast Guard
MD
It sounds to me like you're turning the dimmer switch up too high. That will turn on the map lights. The dash lights come on with the parking lights, the dimmer switch only controls the brightness until you get to the top (should be two detents), first one turns on the map and overhead lights, next one turns on the cargo lights.
VinceOB
VinceOB
Atlanta, GA
I wish it were that easy. With the dimmer all the way off the lights don't come on. When I turn the dimmer one notch up the lights come on.
HemiLonestar
MD
Oh yeah something definitely wrong in there...is it just the map lights or all the overhead lights?
VinceOB
VinceOB
Atlanta, GA
Just the map lights. It's so weird. It worked after I put the new switch in. But, only works half the time.
