dodge_man7
- Dec 20, 2016
- 6
- 0
- 2009
- Hemi 5.7
Hello,
I'm having a strange problem with my map lights. When the dome selector switch is turned all the way to the right the map lights turn on/off and the buttons work, but when the dome selector switch is moved to the left to set the dimmer level I'm unable to turn the map lights on by pressing them. I can press them when the dome selector is all the way to the right but that's the only time they work. What could be causing this or is this how they are designed? I bought the truck used but I don't believe these are LED replaced. Seems like a weird design.
Thank You...
EDIT: Also the map lights work when the door is opened. The button doesn't seem to be the issue since it works when the dome selector turns on the interior lights.
Thank You...
