Max tire size on 2014 PW
Kbhowe1
NM
So what would be the max tire size I could go with on the new PW, it comes stock with 285/70r17. Is there any reason I couldn't put 295/70r17? They about 1/2" taller and .40" wider, would I still be able to disconnect the sway bar? Toyo MT makes one and its a little cheaper than stock size, I really want to get rid of my duratracs.
SETEX 6.4
Port Neches, TX
I don't see why you couldn't even go buffet than that if you wanted to. Should work just fine.
K
Kbhowe1
NM
Yeah would like to go bigger for sure but worried about being able to disconnect sway bar while off roading.
timber man
2014 Power Wagon
I have a 2014 pw and am running a 295 nitto terra grappler mt with no problem
KAKA
