Maxtrac 7" lift with Leveling Kit Question?
mikegmang
hemi
I'm currently getting the Maxtrac 7" kit with a 3" body lift on my 2014 2wd ram 1500. Does anyone know if you can add a Leveling kit on top of the maxtrac kit? I've searched but gotten mixed answers. Basically I'm running 37s on 20" rim an want some extra clearance.
So can I add a 2.5 or 3" level kit on top of the maxtrac 7"?
Maxtrac Suspension
Anaheim, CA
4.7L V8
Hey how's it going? Unfortunately you cannot add an additional spacer lift to our 7" kit. The kit consists of a 4.5" spindle along with a 2.5" lift coil. The spindle and the coil are separate in the way that they work so lets just focus on the coils. Basically our lift coils are already at the max that you will want to put in the vehicle's coil pocket. Trying to stack a spacer (even if it was only a 1" lift spacer) would cause extreme suspension geometry angle issues. So much to the point where the truck would be unsafe to drive, tie rods, control arms, ball joints and everything else would all be at extreme angles and it probably would not align in spec. Even if you looked past all of that, trying to stack a spacer in that coil pocket would probably take 3 guys with huge prybars to get that wedged in and everything to reconnect. With that said, I bet your truck looks pretty sick... have I already seen pics of it? I would love to check it out if you have. Thanks for the support, we appreciate it!
Wandell
Cummins 6.7
Well, there you have it. Straight from the horse's mouth! LOL
